It looks like ic_test2.py is a bad example (i.e. it no longer works).
I should probably just remove it.
ic_test2 was written when I was introducing support for Input Capture, but before the notion of channels was in the code.
ic_test.py is quite similar, but works, and is what is mentioned here: http://wiki.micropython.org/platforms/b ... r-Examples
The ic_cb routine is an interrupt callback routine, and the interrupt handler passes the timer object as the one and only parameter.
So in ic_test.py, the tim argument passed to the callback will be the same as t2.
You can get additional information passed to your callback by using a bound function, like what was done in this example:
https://github.com/dhylands/upy-example ... eat_irq.py (the function and self are bound together, hence the name bound function).
