this is for now nothing more then an idea and this thread should help to do some brainstorming.
For quite some time I'm looking into creating my own keyboard.
The best DIY keyboard I found is called ergodox ... well best in terms what seems important to me.
http://ergodox.org/
Based on this, people created already impressive beautiful keyboards. E.g.
http://almightyglod.com/ErgoDock_Rev1/A ... C_0494.jpg
or
http://geekhack.org/index.php?action=dl ... 2576;image
well the mechanical part is one side. On the other hand it requires a keyboard controller.
ErgoDox is using a Teensy microcontroller board https://www.pjrc.com/teensy/... which I am pretty confident does a good job.
There are already certain versions of firmware with different feature sets.
My idea would be to replace the Teensy board by a pyboard, because I believe the pyboard as a keyboard controller would really show some of the great advantages of the python on a microcontroller.
* Users could easily reprogram almost every function without the need to compile and flash
* Faster prototyping, programming, debugging and testing via python
* More powerful for heavier tasks
* Large storage capacities
* Keep the software/firmware modular it will be easy for each user to configure the functions they need. Again no compiling, no firmware flashing, no makefiles, etc.
We could even consider a plugin catalog if more and more features get contributed.
What I would love to get beside the standard keyboard functions (in no particular order):
* Keyboard layers (done with the teensy already) so you can switch between different keyboard languages, layouts (colemak, dvorak, etc., or e.g. switch to a mode for a certain applications... for example a latex-greek mode in which pressing button "a" will return \alpha
* Add a small display (e-ink?) for certain features
* Integrated password manager: Select a certain entry (via the e-ink display, e.g. ebay) type the master-password and the keyboard will return the individual password. More could be added like password generator, etc.
* Simple Keyboard Macros: Quit similar to Emacs.... after starting a macro every single key-press will be recorded. Stop recording and repeat the macro as often as you want.... a killer-feature for repetitive text editing tasks.
* Complex keyboard macros: Use python to create much more complex macros: E.g. a macro number(10) would return 1 2 3 4 5 6 7 8 9 10
* Add a calculator via the e-ink display, the result can be send via keyboard. E.g. you type 10*0.05/2 and the keyboard will send 0.25 to the PC.
* Unit / Money converter (type 2 inch and the keyboard sends the corresponding value in e.g. cm)
* Mouse emulation by keyboard buttons
* Show system resources on the e-ink display
* 2-way authentication via the keyboard (password and the keyboard are required to grant access)
* store keys and other authentication files for access (e.g. for logins via ssh, encrypt your emails)
* different input methods similar to emacs... e.g. type "o to get ö or ae to get ä. Japanese and Chinese users might even ask for a complete IME (input method editor) via the e-ink display
There is plenty more, which I don't consider important or not really be a core keyboard function (since some would need additional software on the PC side) , but others might find it useful:
* Assistance for bitcoin and other payment systems,
* Logging,
* On-the-fly spell-checking (auto-correction for often misspelled words),
* Email and social network notification even if the PC display is on standby,
* Analyzing of typing habits (e.g. the top 20 words which are followed by backspaces),
* Assistance for certain GTD, Pomodoro, etc. methods
* Notes / TODO taking, (even if PC is off, sync with PC)
* Calendar alarms (even if the PC is off, sync with PC)
* Dictionary
Why doing all this on/in the keyboard directly instead of using host computer software?
Simply because it would work out of the box everywhere on all OSes. If you start to work on another computer, there is no need to install several programs and get your data into it. Simply attach the keyboard and you are ready to go. It will also assist almost any kind of software. If you are a heavy photoshop/gimp user you might get extensive keyboard maps for gimp/photoshop hotkeys. However, if you are a LibreOffice/MS Office user you might have a layer tailored for LibreOffice/MS Office.
Many of the features are even application agnostic:
If you are a programmer, you might get macros and templates for a certain programming language e.g. you type:
ite <tab> # for if then else
if <cursor> :
#add true statement here
#add false statement here
or you want to comment out the next 5 lines of code simply enter the macro mode and write something like:
c5
<Home> #
<Arrow down> <Home> #
My problem?
I always have nice ideas (hope that one is nice
I welcome any ideas, suggestions, comments, help, etc.
<Changelog 28.08.2014>
Added some more examples and reworked the text a bit
