Good afternoon, I want to ask a question about STM32F051. The clock source of systick is 8 frequency division of HCLK and this is the datasheet of STM32F051: http://www.kynix.com/uploadfiles/pdf879 ... 51C4T6.pdf .
The code about my systick.c is given below:
[code]#include "Systick.h"
static __IO uint32_t TimingDelay;
void Delay_ms(__IO uint32_t nTime)
TimingDelay = (nTime*1000);
while(TimingDelay != 0);
void Delay_us(__IO uint32_t nTime)
TimingDelay = nTime;
* @brief Decrements the TimingDelay variable.
* @param None
* @retval None
void TimingDelay_Decrement(void)
if (TimingDelay != 0x00)
TimingDelay--;
void Systick_Init(void)
if (SysTick_Config(SystemCoreClock / 1000000)) //1us
/* Capture error */
while (1);
}[/code]
And then invoking them in main:
[code] LED_Open();
Delay_us(500000);
LED_Close();
Delay_us(500000);[/code]
When in the file--it.c:
[code]void SysTick_Handler(void)
TimingDelay_Decrement();
}[/code]
Then the light can’t flash. Here the default is set to be frequency division.
2)It can operate normally before. The code is :
[code]void Systick_Init(void)
if (SysTick_Config(SystemCoreClock / 1000)) //1ms
/* Capture error */
while (1);
}[/code]
But when invoking them:
[code] LED_Open();
Delay_ms(500);
LED_Close();
Delay_ms(500);[/code]
The SystemCoreClock is set to be: “uint32_t SystemCoreClock = 48000000” and it haven’t be changed.
In this situation it is normal, why? ? ?
The clock configuration about SysTick
Re: The clock configuration about SysTick
Are you porting MicroPyhon to the STM32F051?
If not, then this is definitely the wrong place to be asking about this. I'd recommend that you try the st forums instead.
