I try to run display from Nokia 5110 with pyboard, but it does not work. I combined all variants of SPI options polarity, phase and significant bit, but it is unsuccessfully. What I am doing wrong?
Thanks for any help.
# driver for display Nokia 5110 for micropython
# datasheet pcd8544 here: http://ziblog.ru/wp-content/uploads/2013/03/Nokia5110.pdf
# memo I/Os
# display pyboard state
# DIN -> Y7
# CLK -> Y6
# RST -> Y4 active 0
# CE -> Y5 must be 0 or gnd
# DC -> Y3 commands 0, data 1
# VCC -> 3.3V
# LIGHT -> Y2 active 0
# GND -> GND
class Display:
def __init__(self, spi, rst, ce, dc, light):
# init the SPI bus and pins
spi.init(spi.MASTER, baudrate=328125, bits=8, polarity=0, phase=1, firstbit=spi.MSB)
rst.init(rst.OUT_PP, rst.PULL_NONE)
ce.init(ce.OUT_PP, ce.PULL_NONE)
dc.init(dc.OUT_PP, dc.PULL_NONE)
light.init(light.OUT_PP, light.PULL_NONE)
# store the pins
self.spi = spi
self.rst = rst
self.ce = ce
self.dc = dc
self.light = light
# reset everything
self.ce.high()
self.light.high()
self.rst.low() # A RST pulse must be applied
pyb.udelay(10)
self.rst.high()
# example from datasheet p.22
self.ce.low()
self.dc.low()
self.spi.send(b'\x90')
self.spi.send(b'\x20')
self.spi.send(b'\x0C')
self.dc.high()
self.spi.send(b'\x1F')
self.spi.send(b'\x05')
self.spi.send(b'\x07')
self.spi.send(b'\x00')
self.spi.send(b'\x04')
self.dc.low()
self.spi.send(b'\x0D')
self.spi.send(b'\x80')
def light_on(self):
self.light.low()
def light_off(self):
self.light.high()
def command(self, buf):
self.ce.low()
self.dc.low()
self.spi.send(buf)
def write(self, buf, X, Y):
assert X <= 83
assert Y <= 5
xbyte = X + 128
xbyte = xbyte.to_bytes(1)
ybyte = Y + 64
ybyte = ybyte.to_bytes(1)
self.ce.low()
self.dc.low() # command mode
self.spi.send(xbyte)
self.spi.send(ybyte)
self.dc.high() # data mode
self.spi.send(buf)
#from main.py
#SPI = pyb.SPI(1)
#RST = pyb.Pin('Y4')
#CE = pyb.Pin('Y5')
#DC = pyb.Pin('Y3')
#LIGHT = pyb.Pin('Y2')
#dsp = Display(SPI, RST, CE, DC, LIGHT)
