Minor mistake in Documantation? - class Pin
Hanilein
Post by Hanilein » Thu Oct 18, 2018 8:37 am
The documentation for the class Pin says:
CPU pins which correspond to the board pins are available as pyb.cpu.Name.
For the CPU pins, the names are the port letter followed by the pin number.
On the PYBv1.0, pyb.Pin.board.X1 and pyb.Pin.cpu.A0 are the same pin.
The example is correct, but in the first sentence pyb.cpu.Name must be pyb.Pin.cpu.Name
Otherwise you get an AttributeError: 'module' object has no attribute 'cpu'
Link: http://docs.micropython.org/en/latest/l ... .Pin.html
At first I was not looking at the example, of course - DOH
Ivo Gorny
