Why does my REPL session always have this output
rhubarbdog
Post by rhubarbdog » Wed Mar 27, 2019 10:24 am
When a program terminates and I have a serial terminal open why do I always have this output. I have other micropython devices they just print Micropython version details and the >>> prompt.
>>> AT^SQPORT?
  File "<stdin>", line 1
SyntaxError: invalid syntax
>>> AT
NameError: name 'AT' isn't defined
>>> AT
>>> AT
>>> ~x~~x~
ThomasChr
Re: Why does my REPL session always have this output
Post by ThomasChr » Wed Mar 27, 2019 10:31 am
Does ist also loose characters if you type? Then I also have this problem... resetting and reconneting a few times helps.
As to the cause: I have no idea!
Post by Roberthh » Wed Mar 27, 2019 10:44 am
That's most likely the modem manager on your PC, which tries to activate what it takes as a modem. Please deactivate or better deinstall the modem manager.
kapoira
Post by kapoira » Wed Mar 27, 2019 11:52 am
it happens to my with linux in fedora 30
but i think i have only see it, in micropython 1.10, in micropython 1.8 i don't remember it, (perhaps it's my memory, or that i was using fedora 25/26)
ThomasChr
Post by ThomasChr » Wed Mar 27, 2019 1:02 pm
@Roberthh: Thats a great tip. Yes, sounds like something is trying to access the port and modem manager is very plausible. Will check that. Thanks a lot!
cefn
Post by cefn » Thu Mar 28, 2019 5:36 pm
See https://github.com/adafruit/circuitpython/issues/611 for a bit more detail and workarounds, at least for Debian-based and Ubuntu-based Linuxes.
Post by dhylands » Thu Mar 28, 2019 6:03 pm
Another source of mysterious AT sequences can happen when you use minicom. Some versions may send out init or reset sequences (minicom thinks its talking with a modem) which will confuse Micropython. It's possible to configure your setup to not send these.
I prefer to use picocom over minicom as I find picocom is much easier to get up and running.
cefn
Post by cefn » Thu Mar 28, 2019 8:44 pm
Potentially could use 'vanguard shell' to connect.
It wraps pyserial's miniterm with a micropython-specific terminal configuration and has never spoken to a modem in its life :)
https://pypi.org/project/vgkits-vanguard/
