Newbie: pyboard 1.1 does not work after a firmware update
psereni
Post by psereni » Wed Sep 11, 2019 8:24 am
I have two pyboards 1.1.
for one of them I performed a firmware update as described by O'reilly programming with micropython, i.e. I downloaded the latest pybv11-20190911-v.11***.dfu file and I used the command
$sudo dfu-util --alt 0 pybv11*.dfu
The update process worked apparently ok, but the files are all unreadable and I got a mounting error
REPL seems to work, but the connection starts with errors "file "boot.py", lin1, in <module> NameError: name...... is not defined
and the same for "main.py"....
Thank you for any help
Paolo
Re: Newbie: pyboard 1.1 does not work after a firmware update
Post by Roberthh » Wed Sep 11, 2019 8:35 am
It looks like the file system was damaged. To recreate it, follow the instructions here for boot mode 3:
http://docs.micropython.org/en/latest/p ... boot-modes
psereni
Post by psereni » Wed Sep 11, 2019 8:53 am
Thank you. This was the right thing to do. :)
