Can someone please point me to the documentation related to adding the optional backup battery for the RTC?
RTC Battery Backup
Re: RTC Battery Backup
I don't think that there is any docs. The only thing I found was on this quick-start page:
http://docs.micropython.org/en/latest/p ... ckref.html
You can connect a battery betwen VBAT and Ground.
The STM32F405 data sheet says that VBat needs to be between 1.65V and 3.6V
Thanks for the info.
On the quick-start page the drawing shows VBAT connecting to the two pins above the X22 label. Does that mean the 3.0V battery lead connects to either of the two pins or both?
No, the VBAT pin is the on above X22; X22 is the pin in the outer row, VBAT is the pin in the inner row. Connect the positive terminal of the battery to VBAT, and the negative terminal to ground.
-Bryan
-Bryan
