Sending large array of numbers to host computer
Batman
Post by Batman » Sun Sep 02, 2018 8:45 pm
I use the Pyboard's ADC's to fill up an array with 7500 unsigned short integers. Now I want to send the data to the host computer.
At the side of the Pyboard I'm using
port = pyb.USB_VCP()
port.send(data)
or
port.write(data)
I am having (at least two problems):
1) the data gets truncated. I am not sure what the difference between write() and send() is. However, both of the commands allow me to read out some of the data on the host computer. However, not all: the sent data seems to get truncated. This is, only part of the data arrives at the host computer. For example, only 3000 out of 7500 bytes. Does anybody have an example of how to send larger arrays of data to the host computer?
2) All print statements in my program seem to be sent to the serial port as well. This is great for debugging. However, for my use case, all the print statements end up making it more difficult to find my data in whether arrives at the host computer. It seems I need to implement my own 'mini protocol' that allows me to identify where my data (the 75000 numbers) start and end. Has anybody run into this issue before and found a robust solution?
jickster
Re: Sending large array of numbers to host computer
Post by jickster » Sun Sep 02, 2018 11:38 pm
(1) try increasing the time out; currently it’s set to five seconds
Post by pythoncoder » Mon Sep 03, 2018 5:55 am
@Batman It's not clear from your post how you're doing this. I created the following script and transferred it to the Pyboard as rats10.py:
import array, ujson
a = array.array('h', range(7500))
print(ujson.dumps(a))
At the shell I issued:
pyboard.py --device /dev/pyboard -c "import rats10"
I got back the full array without issue.
Re distinguishing between data and other print statements, I assume you're running Python on the PC. I would attempt a json load in a try-except block. This should reject all but valid json data.
starter111
Post by starter111 » Thu Sep 06, 2018 5:15 pm
Here's what I did on pyboard side. Is slow but works, I was able to send larger data back to computer.
boot.py
sw = pyb.Switch()
pyb.LED(2).on()
pyb.delay(1500)
pyb.LED(2).off()
if not sw():
    pyb.main('pyb_server.py')
pyb_server.py
class USB_Port:
    def __init__(self):
        self.serial = pyb.USB_VCP()
        self.serial.setinterrupt(-1)
    def any(self):
        if self.serial.any():
            return True
            return False
    def read_until(self, ending, timeout=100):
        data = self.serial.read(1)
        timeout_count = 0
            if data.endswith(ending):
                data=data.replace(ending, b'')
                break
            elif self.serial.any():
                new_data = self.serial.read(1)
                data = data + new_data
                timeout_count = 0
                timeout_count += 1
                if timeout is not None and timeout_count >= timeout:
                    break
                pyb.delay(1)
        return data
    def send(self, data):
        self.serial.write(data)
        self.serial.write(b'END')
def run_cmd(cmd):
        exec('d={}'.format(cmd))
        return locals()['d']
    except Exception as e:
        return e
def main(vcp):
        if vcp.any():
            cmd=vcp.read_until(b'END').decode('utf-8')
            data=run_cmd(cmd)
            if data is not None:
                if not isinstance(data, bytes):
                    data = bytes(data, encoding='utf8')
                vcp.send(data)
        pyb.delay(1)
main(USB_Port())
jickster
Post by jickster » Thu Sep 06, 2018 5:16 pm
It’s easier to read your posts if you surround code with the code tags
zaord
Post by zaord » Fri Dec 31, 2021 8:09 am
import array, ujson
@pythoncoder, I can't get make the json.loads() working with array on the PC side. Do you have any solution for using json working with arrays ?
Post by pythoncoder » Fri Dec 31, 2021 12:18 pm
I made a mistake here: JSON doesn't support arrays and it's a quirk that ujson appeared to work here. The following worked under the Unix build of MicroPython. However it's a bit of a hack - I'm not well-up on this stuff and hopefully someone will come up with a better way. Under CPython I believe the best way is using subprocess: feel free to Google ;) Here is the hack.
On Pyboard, rats10.py
import array
print(str(a))
On the PC:
import os
s = """
from array import array
a = """
with open("result.py", "w") as f:
    f.write(s)
os.system('pyboard.py --device /dev/pyboard -c "import rats10" >> result.py')
from result import a
print(a[99])  # a is the array, retrieve an element
I'm sure there's a much more elegant way to do this on MicroPython...
teltonique21
Post by teltonique21 » Tue May 24, 2022 3:35 pm
import os
Is there a way to get the standard output of the launched command? I see you use os.system and redirect to a file which you subsequently read for output. Is there a direct way to get the output just like in Python with subprocess.Popen ?
