rshell mostly works, the one exception I've found in a brief trial being copying files to the WiPy. Support over telnet would be brilliantOnce my WiPy arrives, I was planning on testing it out with that to add support over telnet.
# need to reference the win32 serial stuff
import serial
import binascii
# mocks the bbio interface
# and talks to the attached pyb board using its repl
class I2CDev:
pass
def __init__(self, bus):
# open the serial port
self.serial = serial.Serial("COM3", 115200, timeout=1)
pass
def enter_repl(self):
self.serial.write(b'\r\x02\x04') # soft reset
time.sleep(0.25) # small delay
self.serial.flushInput()
#data = self.serial.read
# send ^A to go into raw repl
# leaving the '>' in the input buffer
self.serial.write(b'\x01')
data = self.serial.readline();
pass
def read_packet(self): # , until):
packet = self.serial.read(1)
while not packet.endswith(b'\x04'):
packet += self.serial.read(1)
return packet[:-1]
def send_command(self, cmd):
print(cmd)
#check weve got a prompt
data = self.serial.read(1)
if data != b'>':
#pass
raise IOError
# send out the data
self.serial.write(bytes(cmd, encoding='utf8'))
# send eof
self.serial.write(b'\x04')
# check OK
data = self.serial.read(2)
if data != b'OK':
raise IOError
# pick up answers
reply = self.read_packet()
error = self.read_packet()
print(reply)
return reply, error
def eval_command(self, cmd):
return self.send_command("print({})".format(cmd))
def open(self):
self.enter_repl()
# and establish an i2c object to chat with
self.send_command("from pyb import I2C")
self.send_command("import ubinascii")
self.send_command("i2c=I2C(1,I2C.MASTER)")
def write(self, address, data):
# formay python statement to run on the pyb
s = "i2c.send(bytes({0}),{1})".format(data, address).replace(' ','')
self.send_command( s ) #"i2c.send(bytes({0}),{1})".format(data, address))
def readTransaction(self, address, reg, count):
data, error = self.eval_command("ubinascii.hexlify(i2c.mem_read({0},{1},{2}))".format(count, address, reg))
# b'00[nnnnnnnnnnn]'\r\n
# nb occasionally we get back empty in repl and raw repl modes
r = data[2:-3]
if len(r) != 2 * count:
print("WTF!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!")
# did we get an error
self.open()
r = data[2:-3]
wtf = binascii.unhexlify(r)
return list(wtf) ##[0]
except:
# reallocate or nothing works??
self.open()
#raise IOError
