machine.bootloader
skylin008
machine.bootloader
Post by skylin008 » Wed Apr 07, 2021 9:35 am
Hello, everyone! I want to enter the bootloader to run machine.bootloader() and keep the pb1 pin is high, but the setting is no invalid, as follow code:
STATIC NORETURN mp_obj_t machine_bootloader(size_t n_args, const mp_obj_t *args) {
    #if MICROPY_HW_ENABLE_USB
    pyb_usb_dev_deinit();
    #endif
    #if MICROPY_HW_ENABLE_STORAGE
    storage_flush();
    #endif
    __disable_irq();
    #if MICROPY_HW_USES_BOOTLOADER
    if (n_args == 0 || !mp_obj_is_true(args[0])) {
        // By default, with no args given, we enter the custom bootloader (mboot)
        [b][u]mp_hal_pin_write(pin_B1, 1);[/u][/b]
        powerctrl_enter_bootloader(0x70ad0000, 0x08000000);
    if (n_args == 1 && mp_obj_is_str_or_bytes(args[0])) {
        // With a string/bytes given, pass its data to the custom bootloader
        size_t len;
        const char *data = mp_obj_str_get_data(args[0], &len);
        void *mboot_region = (void *)*((volatile uint32_t *)0x08000000);
        memmove(mboot_region, data, len);
        powerctrl_enter_bootloader(0x70ad0080, 0x08000000);
    #endif
    #if defined(STM32F7) || defined(STM32H7)
    powerctrl_enter_bootloader(0, 0x1ff00000);
    #else
    powerctrl_enter_bootloader(0, 0x00000000);
    #endif
    while (1) {
How to solve this issue. Thanks!
