pydfu.py run
pydfu.py run
Hello every one! How to direct run(command mode) the pydfu.py update the firmware.dfu file from windows 10. I had a python enviroment.Thanks!
Re: pydfu.py run
I'm pretty sure that pydfu.py will only work on Linux and MacOS and not on Windows. You'll need to use dfu-util (command line) or one of the GUI based DFU loaders (like DFUse) under windows.
