Is it possible to deploy an external SDK with both C and C++ files? I have deployed custom C modules with a couple of C files on either a port or via .mpy files but this seems a much harder task to do and I'm not even sure it's possible .
The makefile (I removed the flags and all the files name for readability) of the SDK I m trying to deploy looks like this :
CC ?= gcc
CXX ?= g++
CFLAGS += list of flags
LDFLAGS += -lm -lstdc++
CSOURCES = list of C sources
CXXSOURCES =list of cpp sources
CCSOURCES =list of cc sources
APP_CSOURCES =source of the custom C function not part of the SDK
COBJECTS := $(patsubst %.c,%.o,$(CSOURCES))
CXXOBJECTS := $(patsubst %.cpp,%.o,$(CXXSOURCES))
CCOBJECTS := $(patsubst %.cc,%.o,$(CCSOURCES))
APP_COBJECTS = $(patsubst %.c,%.o,$(APP_CSOURCES))
all: app
.PHONY: app clean
$(COBJECTS) : %.o : %.c
$(CXXOBJECTS) : %.o : %.cpp
$(CCOBJECTS) : %.o : %.cc
$(APP_COBJECTS) : %.o : %.c
%.o: %.c
$(CC) $(CFLAGS) -c $^ -o $@
%.o: %.cc
$(CXX) $(CFLAGS) $(CXXFLAGS) -c $^ -o $@
%.o: %.cpp
build/lib.so: $(COBJECTS) $(CXXOBJECTS) $(CCOBJECTS)
$(MKDIR_BUILD)
$(CXX) $(COBJECTS) $(CXXOBJECTS) $(CCOBJECTS) -shared -o build/lib.so $(LDFLAGS)
app: $(APP_COBJECTS) build/lib.so
$(MKDIR_BUILD)
$(CXX) $(APP_COBJECTS) build/lib.so -o build/$(NAME) $(LDFLAGS)
clean: clean command
Is the .so file can be a problem ?
I read that some ports don't support C++, if that s true which ones do?
Thank you
