Simple connect liteboard -> rs3231 rtc module
wrightkevin
Post by wrightkevin » Sat Jul 24, 2021 10:40 am
I am trying to connect a MicroPython Lite board to a ds3231 rtc module.
So far I have performed the following steps:
wire connections from the pyboard lite.
x9 -> scl on the module
x10 -> sda on the module
vcc -> vcc on the module
ground -> ground on the module.
Here is my python code:
import ssd1306
from utime import sleep
import utime
rtc.datetime((2005, 7, 23, 1, 12, 48, 0, 0)) # set a specific date and time
print(rtc.datetime()) # get date and time
oled = ssd1306.SSD1306_I2C(128,64, machine.I2C(1))
    oled.fill(0)
    dta = rtc.datetime()
    oled.text( str(dta), 0, 20)
    oled.text( str(dta[2]) + ':' + str(dta[3]) + ':' + str(dta[4]) + ':' + str(dta[5]) \
               + ':' + str(dta[6])
               , 0, 30)
    oled.show()
    sleep(5)
Suffice to say it doesn't work. It just loses the current date/time when removed from power. The ds3231 module has a battery connected and the module does light up. I note that there is no mention of the i2c connection details in the code and suspect this might be relevant.
Please advise.
Kevin Wright
Re: Simple connect liteboard -> rs3231 rtc module
Post by pythoncoder » Sat Jul 24, 2021 1:24 pm
You might want to look at this doc.
wrightkevin
Post by wrightkevin » Sat Jul 24, 2021 3:56 pm
Hi Peter,
Thank you very much for that.
When I run the calibrate function, I get:
Pyboard 1.x. Waiting 5 minutes for calibration factor.
Error 26066.3ppm 49604.1mins/year. Cal factor -27323
But I thought I'd press on anyway. When I use your librarys get_time function, that time does seem to survive a power reset. So I guess that gives me what I need. I'm still trying to get my head round should I be reading from the RTC object or just use your class. Anyway, I think I'm good for now.
Thanks again,
Kevin
Post by pythoncoder » Tue Jul 27, 2021 3:23 pm
The Pyboard Lite does not have a crystal oscillator for the RTC so those error values are to be expected. A Pyboard 1.1 or D with a crystal oscillator can be calibrated to timepiece precision.
