start code from uSD?
nsoatw
Post by nsoatw » Tue May 13, 2014 10:13 am
I like the simplicity of starting the code I want to run by referencing it in boot.py.
Now I'm wondering if there is a way to start code that resides on the uSD-card? Something like:
pyb.main('sd/my_code.py')
nsoatw
Re: start code from uSD?
Post by nsoatw » Thu May 15, 2014 10:39 am
Replying to myself:
accellog.py located in the source-code example folder suggests that 1:/ is used for SD and 0:/ is used for internal flash.
Will try when I get home tonight.
SkG
Post by SkG » Fri May 16, 2014 8:39 am
If you have a SD card in the slot the board will start from it like it was the internal memory. That is it will run boot.py from the SD card when it start or get reseted.
