I have a question about powering the pyboard.
What happens if I first power the pyboard from the USB connector to the PC, and THEN connect the pyboard's Vin to +5v? Will the USB power be disabled?
I ask because I am working on an early prototype PCB with an onboard 5v 2A PSU.
Here are some sequences of events and results:
- 1. When I power the circuit from the PSU, without the pyboard connected, it all seems normal.
2. When I connect the pyboard, it still seems normal.
3. If I then connect the pyboard to the USB connector it still seems normal.
- 1. With the PSU disconnected from the circuit, I connect the pyboard to the PCB
2. I then power the pyboard from the USB connector, it still seems normal.
3. I then power up the PSU, providing now 5v to the pyboard's Vin, the PSU's LM2596 gets burning hot, I can smell it,
4. I disconnect everything before it's too late.
Any thoughts?
Thanks,
Bob
