Now that I have a determined my pyboard RTC needs to be adjusted by a value of -129, what is the best way to apply this adjustment?
I was under the impression that once the correction was applied via: rtc.calibration(-129) it would persist through power cycles with VBAT un-powered, I was wrong.
Maybe the only solution is to add the following lines to boot.py:
rtc=pyb.RTC()
