I want to write a value to the internal non-volatile memory of the uC, so it can be retrieved after a subsequent startup. I don't see a library function to do this in the quick reference guide for the pyboard.
For example, suppose I read a value from the ADC, and I use that value to set a volume control register in an external device using the I2C bus. I would like to recall that volume control setting after reset. I'm looking for a function to allow me to write the value to internal memory, so I can later read it back, to accomplish this.
Regards
Andy
Read/Write uC internal memory
Re: Read/Write uC internal memory
AFAIK, such a function exists only in the form of writing the data to a file.
Thanks very much. I'll look into that idea further. Also my example doesn't make too much sense, since I can just read the ADC again on power-up. But the general question remains (if for example I used a pair of GPIOs to implement up-down buttons, and I want to recall the final volume setting). Another thought is I could have an external memory and read/write to it via I2C or SPI. But my preference would be to use the uC memory to avoid the extra IC.
Regards
Andy
Regards
Andy
You didn't mention which board you're using.
There are functions available on some ports to make the RTC non-volatile memory accessible.
You'll need to add a backup battery in order for the memory to be retained across power cycles.
For the pyboard, see this post: viewtopic.php?f=6&t=7064&p=40196#p40196
Some ports have RTC.memory() (ESP8266 and ESP32) viewtopic.php?f=2&t=7013
