Hi guys,
Always thanks for your all support for the micropython!!!
I made some projects using MICROPYTHON already this year even I am a newbie for coding.
At this time, I need to display data on character LCD display made by Newhaven:https://www.digikey.kr/ko/products/deta ... V3/2626390
Here's my sample code.
I think I should know how to make hex data for this display.
Checked the signal on the SPI data and the clock line by an oscilloscope.
PLZ help me..
from pyb import SPI,I2C,UART
import time,os
spi1=SPI(1, SPI.CONTROLLER, baudrate=100000, polarity=1, phase=1)
#spi1=SPI(1, SPI.PERIPHERAL, baudrate=100000, polarity=1, phase=1) <- It doesn't work.
spiss=pyb.Pin('X5',pyb.Pin.OUT_PP)
spiss(0)
com1=0xfe #default
com2=0x42 # command for display on
data=0x00
spi1.send(b'com1,com2')
pyb.delay(1000)
How to send data using SPI for Newhaven character display.
Re: How to send data using SPI for Newhaven character display.
This line
will send the literal bytes object "com1,com2" which is not what I think you intend. Try
spi1.send(b"\xfe\x42")
Thanks!!!pythoncoder wrote: ↑Sat Dec 11, 2021 9:52 amThis linewill send the literal bytes object "com1,com2" which is not what I think you intend. TryCode: Select all
Now I can understand all things.
