MicroPython startup, No flash drive
GilbertGagne
Post by GilbertGagne » Tue Dec 14, 2021 12:55 am
I'm a newbie with 2 new Pyb v1.1. I've waited until humidity was over 85%
to remove them from anti-static sleeves to avoid zapping them. I've
plugged them into USB port on my Win10 laptop. One Pyb blinks one Led and
the other blinks 3 Leds. Neither Pyb shows up in File Explorer. Program.
Openned Python 3.6 and input "import pyb". reply: ModuleNotFoundError: No module named 'pyb'.
What am I doing wrong?
FeK9
Re: MicroPython startup, No flash drive
Post by FeK9 » Tue Dec 14, 2021 7:19 am
Morning...
Don't own a PyBoard, but maybe this link of MicroPython Documentation 1.17 would help...
https://docs.micropython.org/en/latest/ ... index.html
Post by Roberthh » Tue Dec 14, 2021 7:23 am
A good start would be installing the up-to-date firmware.
GilbertGagne
Post by GilbertGagne » Tue Dec 14, 2021 5:45 pm
According to the referenced doc, the Pyb is correctly connected via USB to PC and PC is running File Explorer. File Explorer does not list any flash drive.
I would like to re-install up to date software but have not found how to do that. Some guidance and/or references would be greatly appreciated.
Post by Roberthh » Tue Dec 14, 2021 6:10 pm
For Download images, go to https://micropython.org/download/?vendo ... 20Robotics
Select the board you own. There you will find the firmware images and load instructions.
nedkonz
Post by nedkonz » Thu Dec 16, 2021 7:08 pm
You're opening Python on your PC, for one thing.
You need to talk to the MicroPython on the pyboard instead, over the USB serial link.
For this you need a communications program.
GilbertGagne
Post by GilbertGagne » Wed Dec 29, 2021 9:43 pm
I tried downloading updated software but found that my USB cable passed power but not data. A new USB cable now reads the PYB Flash drive. Problem solved.
Thank you all for the helpful comments. It sure is comforting to have this rescue forum.
