Hi here !
I have 2 i2c sensors one flowmeter and one bmp280 (temp / pressure sensor).
My fondamental question is I wants to grab my datas on micropython array, encode it with json fromat and send it to serial protocol to a PC Cpython script which will collect various datas.
When I will do my measurements in micropython, I wants to plot my data and compare them versus time.
In my idea, when beetwen the time I will get the value of the first sensor, and the secon a certain amount of time will pass because the measurement process is not instantaneous. So should I feed two array with the value of the sensor and the timestamp of the measurement for each of the different sensor ?
Because, if I have well understood, I think the value stands into the sensor memory but the clocks of the differents sensors are not sync, so I suppose that I need to fix the same sampling rate for both sensor, but I don't know to snyc the time.
Cheers, Ewen
Reading multiples i2c sensor and grab datas regularly
Re: Reading multiples i2c sensor and grab datas regularly
Interesting problem ...
1) how often do you want to take samples?
2) how fast do each of the sensors respond to multiple "take a reading requests"?
3) how close to each other do the two samples need to be taken?
For example (2) 1-wire DS18b20 normal conversion period takes about 750ms.
1) I needs maybe 150 Samples / s (150 Hz) for each sensors. This is not critical because it's fluid dynamics measurements for musical acoustics and those processes are slow.davef wrote: ↑Wed Dec 29, 2021 7:46 pmInteresting problem ...
1) how often do you want to take samples ?
2) how fast do each of the sensors respond to multiple "take a reading requests" ?
3) how close to each other do the two samples need to be taken ?
2) The max sampling frequency of the sensor is 200 Hz
3) It's not really the question. I need to be sure that the time interval beetwen two sample really steady and the samples on the two sensors taken on the same sampling frequency, but I could also use a propoer python script to resample my signal , because i could afterwards delay it of make data analysis and resync them.
I plan to reuse this code founded here :
from micropython import const
def read_samples(self, acquisition_time):
# set up
n_exp_meas = floor(acquisition_time * ceil(self.sampling_rate))
buf_sens1 = bytearray(6 * n_exp_meas)
buf_sens2 = bytearray(6 * n_exp_meas)
m1 = memoryview(buf_sens1 )
m2 = memoryview(buf_sens2)
n_act_meas = 0
# read bytes as fast as possible
start = time.ticks_us()
while time.ticks_diff(time.ticks_us(), start) < acquisition_time * 1000000:
curr_time = time.ticks_us()
if time.ticks_diff(curr_time, start) < (n_act_meas * 999999. / self.sampling_rate):
continue
# read sensor 1
self.i2c.readfrom_mem_into(self.address, self.regAddress, m1[n_act_meas * 6:n_act_meas * 6 + 6])
# grab the time of the measure 1
time_sensor1[n_act_meas ]= curr_time
# read sensor 1
self.i2c.readfrom_mem_into(self.address, self.regAddress, m2[n_act_meas * 6:n_act_meas * 6 + 6])
# grab the time of the measure 2
time_sensor2[n_act_meas ]= curr_time
n_act_meas += 1
# bytes --> lists of integers
acc_x, acc_y, acc_z = zip(*[ustruct.unpack('<HHH', buf[i:i+6]) for i in range(len(buf)) if i % 6 == 0])
del buf, m
gc.collect()
# remove exceeding zeros
acc_x = acc_x[:n_act_meas]
acc_y = acc_y[:n_act_meas]
acc_z = acc_z[:n_act_meas]
print("measured samples: ", n_act_meas)
print("expected samples: ", n_exp_meas)
print("actual sampling rate: ", n_act_meas / acquisition_time)
return acc_x, acc_y, acc_z
3) what timing resolution or allowable offset between the samples for the two devices, ie microseconds?
3a) how accurate does the sampling rate have to be?
1-2 ms is engouh, It is just for a good human interpretation
It's just I will make transitent analysis, so I just need the two signal in phase as much as I can
I re-read this:
viewtopic.php?f=18&t=8443
so I am guessing that reading two I2C devices using softI2C could take 500us.
Writing to them, similar, unless he meant write/read? And that doesn't include the processing times to issue the two commands.
My question is basically, should I need to take the time stamp of a measurement before this measurement or after ?
If the write and read times are the same then taking:
1) one time measurement between the two writes,
2) before both writes or
3) after both reads
is still going to give the same error. I am sure it is probably not that easy.
Sorry, I was probably too focused on the issue of getting the two readings in a timely fashion.
3) after both reads
