Hi
I'm following the MicroPython tutorial, but having trouble with the "Making the pyboard act as a USB mouse and keyboard" .
[Using MicroPython v1.13 on 2020-09-02; PYBv1.1]
1] For mouse:
The controller does not seem to work when pyb.usb_mode('VCP+HID') is uncommented in the boot.py file.
In main.py have put following code-
switch = pyb.Switch()
accel = pyb.Accel()
hid = pyb.USB_HID()
while not switch():
hid.send((0, accel.x(), accel.y(), 0))
pyb.delay(20)
After saving codes, ejected the pyboard and then had reset it as mentioned in MicroPython documents. After this green LED is continuously blinking and in devices(in windows os) it's showing com connected as mouse FS mode but the code in main.py is not reflecting.
2] For keyboard:
The controller does not seem to work when pyb.usb_mode('VCP+HID', hid=pyb.hid_keyboard) is uncommented in the boot.py file. Also tried with pyb.usb_mode('HID').
h = pyb.USB_HID()
def kb_press(x):
b = bytearray(8)
b[2] = x # key press
h.send(b)
time.sleep_ms(25)
b[2] = 0 # key release
h.send(b)
kb_press(4) # press "a" once
After saving codes, ejected the pyboard and then had reset it as mentioned in MicroPython documents. After this green LED is continuously blinking. But not able take input. In this connection is also not showing in device(in windows os).
Am I missing something here to use it properly, please suggest.
Thank you.
