Timer Callback executed just once
Sokrates
Post by Sokrates » Sun Dec 20, 2015 6:35 pm
I'm at a very early stage of python programming language so please be patient :)
I'm trying to make my timer working and should be quite straight forward following the tutorial...but it is not :(
Basically my problem is that the callback function seems to be executed just 1 time, so that the updateLed flag is not updated to true any more and the if statement is always false.
I think I'm doing some very basic error.
Could you please have a look?
In general I need to have 2 or 3 timers running simultaneously and I'm trying to set just flags values into their related callbacks in order to not block the stack and execute the code in the main loop. Is that the current approach?
updateLed = False
led = pyb.LED(4)
def statusLed():
    global updateLed
    updateLed=True
    led.toggle()
tim1 = pyb.Timer(1)
tim1.init(freq=1)
tim1.callback(statusLed())
    i = 0;
    if updateLed == True:
       updateLed=False
       print('Test: ',i)
       i = i+1
Re: Timer Callback executed just once
Post by dhylands » Sun Dec 20, 2015 7:00 pm
Try changing this line:
to look like:
tim1.callback(statusLed)
When you create timer callbacks, they also need to take a single argument, which is the timer, so you'll also need to modify:
def statusLed():
to look like:
def statusLed(tim):
What your original code did was to call statusLed() and pass the results of calling that function to tim1.callback. In python if a function doesn't explicitly return anything, then it behaves as if you had returned None. So your original code was equivalent to the following code snippet:
statusLed()
tim1.callback(None)
By removing the () you pass the statusLed function. With the parenthese you call the statusLed function and pass what statusLed() returns. A subtle, but very important distinction.
You probably want to move your i = 0 outside of the while loop, otherwise it will reassigned 0 each time through the loop.
Sokrates
Post by Sokrates » Sun Dec 20, 2015 7:17 pm
dhylands wrote:Try changing this line:
to look like:
def statusLed():
to look like:
def statusLed(tim):
statusLed()
tim1.callback(None)
Thanks Dave! You saved me :)
Initially I didn't put the () on the function call, but since the code wasn't working I tried to change some stuffs. Anyway I think the biggest error I made is not passing tim1 as argument to the callback. Now everything is working fine.
Thanks a million!
Post by dhylands » Sun Dec 20, 2015 7:29 pm
Also, if you're using interrupts (a timer callback is an interrupt) then I highly recommend than you add these lines to your code:
import micropython
then when you do have errors in your callback code, you'll get a much better error report rather than just MemoryError.
