My attempt to install this has left my Pyboard with the LED's apparently showing DFU mode on power up. But it doesn't respond to an attempt to upload a build, nor does it respond to the user switch on boot. The board seems totally FUBAR. Is there any way to retrieve it? Here is a dump of the session.
$ sudo dfu-util -d 0483:df11 -a 0 -D pybv10-2016-01-13-v1.5.2-54-gefc971e.dfu
[sudo] password for adminpete:
dfu-util 0.5
(C) 2005-2008 by Weston Schmidt, Harald Welte and OpenMoko Inc.
(C) 2010-2011 Tormod Volden (DfuSe support)
This program is Free Software and has ABSOLUTELY NO WARRANTY
dfu-util does currently only support DFU version 1.0
Filter on vendor = 0x0483 product = 0xdf11
Opening DFU USB device... ID 0483:df11
Run-time device DFU version 011a
Found DFU: [0483:df11] devnum=0, cfg=1, intf=0, alt=0, name="@Internal Flash /0x08000000/04*016Kg,01*064Kg,07*128Kg"
Claiming USB DFU Interface...
Setting Alternate Setting #0 ...
Determining device status: state = dfuERROR, status = 10
dfuERROR, clearing status
Determining device status: state = dfuIDLE, status = 0
dfuIDLE, continuing
DFU mode device DFU version 011a
Device returned transfer size 2048
Dfu suffix version 11a
DfuSe interface name: "Internal Flash "
file contains 1 DFU images
parsing DFU image 1
image for alternate setting 0, (2 elements, total size = 281956)
parsing element 1, address = 0x08000000, size = 14504
parsing element 2, address = 0x08020000, size = 267436
Error during second get_status
[adminpete@axolotl]: ~/Downloads
dfu-util 0.5
No DFU capable USB device found
