How to call linux bash from micropython
Hello,every one! I want to using efax software,How to call efax command line from micropython.Thank you very much!
Re: How to call linux bash from micropython
>>> import uos
>>> uos.system('ls -l')
total 40
-rw-r--r-- 1 adminpete adminpete 1006 Feb 20 2016 ffilib.py
drwxr-xr-x 2 adminpete adminpete 4096 Aug 7 2015 json
-rw-r--r-- 1 adminpete adminpete 196 Jul 29 11:27 pickle.py
drwxr-xr-x 2 adminpete adminpete 4096 Oct 13 07:18 __pycache__
-rw-r--r-- 1 adminpete adminpete 76 Oct 24 07:12 rats1.py
-rw-r--r-- 1 adminpete adminpete 95 Oct 24 07:14 rats2.py
-rw-r--r-- 1 adminpete adminpete 67 Oct 24 07:16 rats.py
-rw-r--r-- 1 adminpete adminpete 4886 Aug 7 2015 re.py
lrwxrwxrwx 1 adminpete adminpete 65 May 15 2016 upython -> /mnt/qnap2/data/Projects/MicroPython/micropython/unix/micropython
0
Thanks pythoncoder support.I will be try and check it out!
Hello pythoncoder,
when I run the uos.system function,the error logs as follow:
>>> import os
>>> import uos
>>> uos.system()
AttributeError: 'module' object has no attribute 'system'
How to solve this issue,Thanks!
>>> import os
>>> import uos
>>> uos.system()
The module is called "uos". You need to pass the command you're trying to call to the system() function.
Are you, perhaps, trying to run this on pyboard?
>>> import uos
>>> uos.system('uname -a')
Linux arch 4.7.6-1-ARCH #1 SMP PREEMPT Fri Sep 30 19:28:42 CEST 2016 x86_64 GNU/Linux
@platforma Good point. I did assume that the original post referred to the Unix build owing to the reference to Bash
@skylin008 If you're running MicroPython on a Pyboard, ESP8266 or other hardware, you can't access a Bash prompt because these boards don't run Linux. They run MicroPython directly on the microprocessor; there is no operating system and no Bash shell. It will produce the error message you're seeing.
I guess what he wanted to do is to call a bash script on the host pc triggered by an event within e.g. a pyboard.
Easiest to to that would be to write a small python script for the host machine, which communicates via the virtual serial port with the pyboard. As soon as the pyboard sends a command, the script will execute the commands like shown in Peters example.
