What are the "P" pins for?
Posted: Fri Dec 23, 2016 5:24 am
by harambecute101
I have a pyboard V1.0 lite.
I was soldering on headers to my board and I found out that the 2nd row from the bottom of the board are all labeled as "p-something" and not X or Y, like on the sides of the board.
What are these for?
Are they analog or digital?
Why are they labeled "P?"
Re: What are the "P" pins for?
Posted: Fri Dec 23, 2016 6:16 am
by dhylands
Looking at the schematic for the PYBLITE: http://micropython.org/resources/PYBLIT ... matics.pdf the P pins are all assigned to other functionality.
P1 - aka DFU
P2 - PB4 - Blue LED
P3 - PA15 - Yellow LED
P4 - PA14 - Green LED
P5 - PA13 - Red LED
P6 - VBACKUP - backup battery for RTC
P7 - V+
P8 - GND
The X and Y pins are a rotated version of each other, so that if you made an expansion board that fitted on the X pins, then you could rotate it 180 degrees and it would fit on the Y pins, with mostly the same functionality (as far as SPI, I2C, UART) is concerned.
Posted: Fri Dec 23, 2016 8:47 am
by harambecute101
THANKS!!!!!! That was the info I was looking for the past month!!!! THANKS!!!
Posted: Sun Dec 25, 2016 11:48 pm
by smurfendrek123
What are pin p2 - p5 supposed to be used for? Should one use them like other gpio pins?
Posted: Mon Dec 26, 2016 6:14 am
by dhylands
They're connected to the LEDs on the board. You can use them as general purpose outputs if you don't mind the LEDs flashing and don't plan on using the LEDs for anything else.
It would allow you to install external LEDs (in the event that the on-board ones weren't visible).
