Showing jpeg file on LCD160
kamikaze
Post by kamikaze » Sat Feb 25, 2017 8:29 pm
Hi. Is there any example on this topic? Also how to get the right format of jpeg file.. Right now I'm getting huge random text output instead of image.
 1 import pyb
 2 from lcd160cr import LCD160CR, PORTRAIT_UPSIDEDOWN
 3
 4
 5 def test_ignitor(base_pin_name='Y12'):
 6     pin = pyb.Pin(base_pin_name)
 7     lcd = LCD160CR('X')
 8     lcd.set_orient(PORTRAIT_UPSIDEDOWN)
 9     lcd.set_text_color(lcd.rgb(255, 0, 0), lcd.rgb(0, 0, 0))
10     lcd.set_font(3)
11     lcd.erase()
12
13     with open('/sd/frames/nuclear.jpg', 'r') as f:
14         nuclear = f.read()
15
16     countdown = 15000
17     remaining = countdown
18     start = pyb.millis()
19
20     while True:
21         remaining = countdown - pyb.elapsed_millis(start)
22         lcd.erase()
23         lcd.set_pos(0, 0)
24
25         if remaining <= 0:
26             break
27
28         lcd.write('{}'.format(remaining))
29
30         pyb.delay(50)
31
32     lcd.erase()
33     lcd.set_pos(0, 0)
34     lcd.jpeg(nuclear)
Re: Showing jpeg file on LCD160
Post by pythoncoder » Sun Feb 26, 2017 7:46 am
I can't make this work either. As far as I can see the following should work but in practice it merely erases the screen.
buf = bytearray(10000)
with open('/sd/test.jpg', 'rb') as f:
    f.readinto(buf)
lcd = LCD160CR('Y')
lcd.set_pen(0, 0)
lcd.erase()
lcd.set_pos(0,0)
The test file is available here http://hinch.me.uk/lcd/test.jpg. It's a 53x53 pixel jpeg created from a photo using Gimp.
I will raise an issue on GitHub.
chuckbook
Post by chuckbook » Sun Feb 26, 2017 12:40 pm
LCD160CR accepts raw jpeg encoded files up to a certain size (~65000 bytes). Only very basic parameters of the jpeg stream are evaluated. No EXIF decorators are accepted!
It is a good idea to strip the jpeg files used with something like:
For the example @pythoncoder provided , this results in a reduced file size of 1872 instead of 9590 bytes.
kamikaze
Post by kamikaze » Sun Feb 26, 2017 11:52 pm
chuckbook wrote:LCD160CR accepts raw jpeg encoded files up to a certain size (~65000 bytes). Only very basic parameters of the jpeg stream are evaluated. No EXIF decorators are accepted!
jpegtran may increase the size too. Here is the JPEG file saved from Gimp.
$ ls -l frames/nuclear.jpg
-rw-r--r-- 1 kamikaze kamikaze 23551 feb 25 22:16 frames/nuclear.jpg
Running:
$ jpegtran frames/nuclear.jpg > frames/nuclear_m.jpg
Result:
$ ls -l frames/nuclear_m.jpg
-rw-r--r-- 1 kamikaze kamikaze 25556 feb 27 01:49 frames/nuclear_m.jpg
Post by pythoncoder » Mon Feb 27, 2017 8:13 am
I can confirm that stripping the EXIF data by the method suggested by @chuckbook fixed the problem.
chuckbook
Post by chuckbook » Mon Feb 27, 2017 5:19 pm
@kamikaze Good point! Don't forget '-o' option for jpegtran! With this option the test file from @pythoncoder will reduce to 1537 bytes.
Post by pythoncoder » Wed Mar 01, 2017 6:42 am
What is perhaps needed is a utility to run on a PC which takes as input a JPEG file and outputs Python sourcecode. The latter would declare a bytes instance containing the data and a function returning a memoryview of that instance. The Python file could then be frozen as bytecode. That way the JPEGS would consume almost zero RAM. The user would then do something like
import my_image
lcd = LCD160CR('Y')
lcd.set_pen(0, 0)
lcd.erase()
lcd.set_pos(0,0)
The same idea as already used for fonts: https://github.com/peterhinch/micropyth ... -to-py.git. This would mainly be of value if people were using large or multiple JPEGs.
If there's any interest I could do this.
