Hi uPy Forum
Just got my pyboard v1.0 2 days ago and fall in love with it.
Here is what i want to do:
Auto move the servo from -90 to 90 repeatedly
The button input from 'X17' which is the on board button when pressed will turn the LED(1) on which is red.
However i could not get it to work the way i want. Can anyone give me some guide? Thanks
And here is my code:
sw = pyb.Pin('X17', pyb.Pin.IN, pyb.Pin.PULL_UP)
le = pyb.LED(1)
servo1 = pyb.Servo(1)
servo1.angle(-90)
pyb.delay(500)
servo1.angle(90)
pyb.delay(500)
if sw.value == 0:
le.on()
le.off()
The button is not working during the pyb.delay periods. I know the problem but doesnt know how to get around this.
Thanks first guys.
Without delay(), how hard is it?
Re: Without delay(), how hard is it?
The standard trick to do this is called "blink without a delay" and involves running the loop without any delays, but only doing things inside it if the time elapsed since the last time is greater than some value. For example:
last_button = last_servo = utime.ticks_ms()
servo_angle = 90
led_state = False
now = utime.ticks_ms()
if utime.ticks_diff(now, last_servo) > 500:
servo1.angle(servo_angle)
servo_angle = -servo_angle
last_servo = now
if utime.ticks_diff(now, last_button) > 200 and not sw.value():
led_state = not led_state
le.value(led_state)
last_button = now
There are also other ways, such as interrupts, asyncio or even threads, but I think this is an important trick to have up your sleeve.
Thanks for the info and the code. I trying the code atm but its said ticks_ms is not define
I try to look up the library from this link but i cant find any library for utime https://pypi.python.org/pypi?%3Aaction= ... icropython
Did i miss step somewhere?
utime is built-in, you just have to import it
>> "blink without a delay" (...) For example:
Deshipu, thank you for this implementation, sth exactly like this should be in utime module docs.
Perhaps instead of this:
# Calculate deadline for operation and test for it
deadline = ticks_add(time.ticks_ms(), 200)
while ticks_diff(deadline, time.ticks_ms()) > 0:
do_a_little_of_something()
Cheers!
Cheers!
This approach is fine for very simple programs but the event loop soon gets convoluted as the number of events to be handled increases. You can write more modular and object oriented code using asyncio. Consider this code which flashes the four Pyboard LED's asynchronously for ten seconds:
If you had, say, 16 LED's all you'd need to change is a single number. With a hand crafted event loop, the loop code would increase substantially. For anyone unfamiliar with asyncio async repo includes a tutorial.
import uasyncio as asyncio
async def killer(duration):
await asyncio.sleep(duration)
async def toggle(objLED, time_ms):
await asyncio.sleep_ms(time_ms)
objLED.toggle()
leds = [pyb.LED(x) for x in range(1,5)] # Initialise all four on board LED's
for x, led in enumerate(leds): # Create a coroutine for each LED
t = int((0.2 + x/2) * 1000)
loop.create_task(toggle(leds[x], t))
loop.run_until_complete(killer(10)) # Run for 10s
Thank you Peter!
I'll sit down to understand this in the evening : )
I'll look into uasyncio tutorial as well.
Cheers! : )
Cheers! : )
