I have built arm-none-eabi-gcc on my PC, and it could be found by using "TAB". However, when I use the console "make BOARD=PYBV11", it always shows that:
make:execvp:/usr/bin/gcc/arm-none-eabi-gcc: Not a directory.
How should I do to solve this problem? Many thanks...
Questioning in gcc "make"
Re: Questioning in gcc "make"
It's hard to be sure without more detail. Here arm-none-eabi-gcc is an executable in /usr/bin and there is also a directory /usr/arm-none-eabi with various subdirs. My path is
[adminpete@axolotl]: ~
$ echo $PATH
/home/adminpete/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/mnt/qnap2/Scripts:/mnt/qnap2/data/Projects/MicroPython/xtensa-lx106-elf/bin
