Which firmware version do I have installed?
Is there any way of finding out which firmware version I have installed on my pyboard?
Last edited by christian.prosser on Thu Nov 13, 2014 9:28 pm, edited 1 time in total.
Onlinedhylands
Re: Which firmware version do I have installed?
When the pyboard boots, it prints a banner (on the usb serial port) that looks something like the following:
If you don't see it - Press RETURN until you get the >>> prompt and then press Control-D which should soft-reboot and print the banner again.
The v1.3.5 corresponds to a tag in the git repository. It will get some additional stuff added if you do a custom build and have modified any of the files.
Micro Python v1.3.5 on 2014-11-01; PYBv1.0 with STM32F405RG
Thanks Dave!
Small variation of this question... Are there any preferred firmware versions ore are all still to be considered "in development" so that we always should use the latest ones? Watching the steady release logs is always like standing in front of the christmas tree back then
Onlinedhylands
Pretty much the latest is usually the best.
is there a way to retrieve the firmware version from python? e.g. pyb.version() or could add it to pyb.info()
If you want a stable and known-to-be-working version, always go with something that has a "simple" version number; eg v1.3.10 without any gxxxxxx garbage at the end.
That said, the latest version (with -gxxxxxx.dfu at the end) is generally ok and has latest features and bug fixes.
No, not possible at this point in time.is there a way to retrieve the firmware version from python? e.g. pyb.version() or could add it to pyb.info()
Ah, looks likes the new os.uname() does what I needed ...
thanks.
my other wish is that gc_collect() keep a running count of the number of garbage collections and a function to fetch that count.
>>> import os
>>> os.uname()
(sysname='pyboard', nodename='pyboard', release='1.4.2', version='v1.4.2-16-gfd787c5-dirty on 2015-04-23', machine='PYBv1.0 with STM32F405RG')
You may also find sys .implementation useful.
How would you use the information about the total number of GCs? A way that might work for you is to disable auto GC using gc.disable() then force a GC yourself in your main loop with gc.collect(). Then just increment your own counter.
GC is a mystery to me, and the fact that it consumes more than a millisecond and occurs "unpredictably" doesn't give me a warm feeling. So i'd like to know if GC is going on in modules that I may not have authored.Damien wrote: How would you use the information about the total number of GCs? A way that might work for you is to disable auto GC using gc.disable() then force a GC yourself in your main loop with gc.collect(). Then just increment your own counter.
I've added a gc_cnt++ to stmhal/gccollect.c and report it in modpyb.c in the pyb.info() GC stuff. I'm running various things on the pyboard and "observing" ... inquiring minds.
