urequests.post failures
dentex
Post by dentex » Wed Oct 25, 2017 6:12 pm
Hello!
This is my 1st post here; I hope I'm not breaking any rules.
I'm trying to receive notifications on my (Android) mobile device from an ESP8266 MCU running Micropython. For this reason I subscribed to a couple of online services exposing some APIs for this task, Pushbullet and Pushed, and I installed the matching apps on my device.
This is what I'm trying:
Pushbullet:
[code]import json
import urequests
body = "Test Notification"
title = "Pushbullet"
data_sent = {"type": "note", "title": title, "body": body}
API_KEY = 'xxxxxxxxxxxxxxxxxxxxxxxxxxx'
pb_headers = {
'Authorization': 'Bearer ' + API_KEY,
'Content-Type': 'application/json'
r = urequests.post(
'https://api.pushbullet.com/v2/pushes',
data=json.dumps(data_sent),
headers=pb_headers
print(r)[/code]
Error:
[code]ssl_handshake_status: -256
File "<stdin>", line 11, in <module>
File "urequests.py", line 104, in post
File "urequests.py", line 56, in request
OSError: [Errno 5] EIO[/code]
Pushed:
[code]import json
import urequests
payload = {
"app_key": "xxxxxxxxxxxxxxxxxxxxxxxxxxx",
"app_secret": "xxxxxxxxxxxxxxxxxxxxxxxxxxx",
"target_type": "app",
"content": "Remote Mic MCU test from ESP8266"
r = urequests.post("https://api.pushed.co/1/push", data=payload)
print(r)[/code]
Error:
[code]Traceback (most recent call last):
File "<stdin>", line 8, in <module>
File "urequests.py", line 74, in request
TypeError: object with buffer protocol required[/code]
Searching for those errors doesn't get me anywhere useful.
The exact same code snippets work ok on my Linux box (using requests instead of urequests), but I understand that urequests may have some limitations. Do you have any hint on how to fix this? Thanks.
dentex
Re: urequests.post failures
Post by dentex » Thu Oct 26, 2017 7:04 am
Anyway, why BBCode is OFF? :?
torwag
Post by torwag » Thu Oct 26, 2017 10:10 pm
First posts do not allow bbcode as some spammers used it to send pictures not only of naked PCBs but of other naked things....
As we need to approve the first posts and they always open up full for approval, we had an office-rules violation from time to time ;)
Now it should work for you
SpotlightKid
Post by SpotlightKid » Sun Oct 29, 2017 2:07 pm
data needs to be of type bytes or bytearray, not a dictionary.
If you want to send JSON encoded data, use the json keyword arg, passing a dictionary to it:
r = urequests.post(url, json=dict(foo='bar'))
See the source here:
https://github.com/micropython/micropyt ... sts.py#L35
dentex
Post by dentex » Tue Oct 31, 2017 8:59 pm
Unfortunately, still no joy (unless I'm missing something).
Thanks for the reply. I'll take a look into this.
For the moment, I have the "pushbullet" part working (https://github.com/micropython/micropython/issues/3389).
dentex
Post by dentex » Fri Nov 03, 2017 9:37 am
So I tried again with Pushed: using the json keyword as suggested, the request goes, but the response text is:
{"error":{"type":"empty_credentials","message":"You must introduce account credentials to make requests. Please read the documentation available in https:\/\/about.pushed.co\/docs."}}
SpotlightKid
Post by SpotlightKid » Fri Nov 03, 2017 6:42 pm
This API endpoint form pushed.co actually expects form-encoded values not JSON:
https://about.pushed.co/docs/api#api-method-push
In CPython's urllib.request.urlopen and requests.post you can just pass a dictionary to the data keyword parameter and the keys and values will be send as the form-encoded body and appropriate headers will be set. Not so in urequests. There you have to do the form-encoding yourself. If you're not short on memory, you can install the urllib.parse module from micropython-lib and use it like this.
import urequests
from urllib.parse import urlencode
url = 'http://httpbin.org/post'
data = dict(foo='bar', spamm=42)
headers = {'Content-Type': 'application/x-www-form-urlencoded'}
response = urequests.post(url, data=urlencode(data), headers=headers)
print(response.json())
But it's a very heavy module and contains many things that you might not need. You might want to just copy and paste the quote, quote_plus and urlencode functions from it into your code.
SpotlightKid
Post by SpotlightKid » Sat Nov 04, 2017 5:07 pm
Here's an example, where I did just that. You still need the urequests and collections.defaultdict module from micropython-lib.
https://gist.github.com/SpotlightKid/ec ... 635f62ab73
dentex
Post by dentex » Mon Nov 06, 2017 6:57 pm
Hello SpotlightKid,
thank you very much for your answer.
I'll try to implement it and I'll let you know. :)
