CAN Library
Gabrielojim
CAN Library
Post by Gabrielojim » Sun Oct 29, 2017 10:20 pm
Hello:
I want to know how I can modify the code of the CAN library, that is I need to access to the code of the CAN library, change it and then load it again in the Pyboard.
Thanks a lot for your help!!!
SpotlightKid
Re: CAN Library
Post by SpotlightKid » Tue Nov 21, 2017 10:05 am
You would need to alter the C source code of the module and recompile and flash the firmware. Here's the source for the module in the stm32 port:
https://github.com/micropython/micropyt ... tm32/can.c
See the readme at the root of the repository on information how to compile the firmware.
Chris
