Hello:
I want to know how I can modify the code of the CAN library, that is I need to access to the code of the CAN library, change it and then load it again in the Pyboard.
Thanks a lot for your help!!!
CAN Library
Re: CAN Library
You would need to alter the C source code of the module and recompile and flash the firmware. Here's the source for the module in the stm32 port:
https://github.com/micropython/micropyt ... tm32/can.c
See the readme at the root of the repository on information how to compile the firmware.
Chris
Chris
