A special case in bytes decode function
Posted: Sun Nov 05, 2017 8:53 am
by swanduron
I try to convert a bytes to str, but uPy gives some unreasonable result as below, anyone can explain this case?
uPY 1.9.2
>>> b'\xa5'.decode()
>>> b'\xa5'.decode() == '%'
False
>>> b'%'.decode() == '%'
True
General PY 3.5.2
>>> b'\xa5'.decode('utf8')
File "<pyshell#22>", line 1, in <module>
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xa5 in position 0: invalid start byte
Re: A special case in bytes decode function
Posted: Sun Nov 05, 2017 9:05 am
by swanduron
Sorry for my mistake, my question is, why the b'\xa5' is not equal with char '%'? and, why b'\xa5' can not be decoded by any coding in general Python.
Posted: Sun Nov 05, 2017 10:03 am
by deshipu
A bytes object is not equal to a string object, because they have different types.
Python3 can't decode bytestring b'\xa5', because that byte signifies a start of a multi-byte sequence in utf8, and should be followed by more bytes specifying what character it actually is. MicroPython doesn't care, because its utf8 support is very rudimentary and hacky, due to size constraints.
Does that make sense?
Posted: Mon Nov 06, 2017 3:26 pm
by pfalcon
$ micropython
MicroPython v1.9.3-32-g7434a67a5-dirty on 2017-11-05; linux version
Use Ctrl-D to exit, Ctrl-E for paste mode
>>> b'\xa5'.decode()
UnicodeError:
Posted: Mon Nov 06, 2017 5:05 pm
by dhylands
You get something similar in Python3:
Python 3.5.3 (default, Sep 24 2017, 15:18:48)
[GCC 5.4.0 20160609] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> b'\xa5'.decode()
Rather than trying to convert b'\xa5' to a character (which you can't since b'\xa5' isn't a valid unicode character) why don't you just compare to b'%' ?
