I have seen some amazing code in Peter Hinch's, https://github.com/peterhinch/micropython-async, repository. I would like to know how to get the required uasyncio module (which is part of micropython-lib) onto the PyBoard. I have V1.1 of the board. What is a good way to get the required modules from micropython-lib onto the pyboard so that I can use uasyncio and required modules?
Rich
Getting some or all micropython-lib onto pyboard
Re: Getting some or all micropython-lib onto pyboard
* Install the unix port of micropython.
* Install rshell (https://github.com/dhylands/rshell).
* Download and install the module with upip:
* Use rshell to copy the module onto the pyboard's flash:
* Or use its 'rsync' command to copy everything:
micropython -m upip install micropthon-uasyncio
rshell cp ~/.micropython/lib/uasyncio.py /flash
rshell rsync ~/.micropython/lib/ /flash
@RWLTOK Thank you for your kind remark
But I do explain the installation process at the start of my tutorial...
It's also officially documented here.
SpotlightKid wrote: ↑Mon Dec 18, 2017 11:59 am* Install the unix port of micropython.
* Use rshell to copy the module onto the pyboard's flash:Code: Select all
* Or use its 'rsync' command to copy everything:Code: Select all
When i use first command on rshell,, i get the following error.
Do you know what's the problem here or can you help me in installing uasyncio.Welcome to rshell. Use Control-D to exit.
/home/edutech> micropython -m upip install micropython-uasyncio
Unrecognized command: micropython -m upip install micropython-uasyncio
/home/edutech>
All the commands are given as shell commands, you run them directly from the terminal, not from within rshell.
