I'm asked to evaluate the Pyboard v1.1 as the controller board for a demo project. At the moment the main requirements are related to the I/O channels in two use cases:
CASE 1:
6x digital inputs, 1x UART (with RTS CTS flow control)
CASE 2:
1x ADC, 1x UART (with RTS CTS flow control), 3x digital inputs, 3x digital outputs, 1x DAC
Can you confirm the suitability of the Pyboard v1.1 for the above requirements ? Any advice ?
Thanx
Info about Pyboard v1.1 I/O
Re: Info about Pyboard v1.1 I/O
The documentation for the UART shows how to initialize a UART with flow control:
http://docs.micropython.org/en/latest/p ... .UART.init
and the board definition file for the PYBV11 shows that UARTs 2 & 3 have hardware flow control.
This image shows the digital/analog pins which are available:
https://store.micropython.org/product/PYBv1.1#image5
The RTS/CTS pins aren't shown there, but from the board definition file:
Disclaimer: I haven't personally used hardware flow control.
#define MICROPY_HW_UART2_RTS (pin_A1)
#define MICROPY_HW_UART2_CTS (pin_A0)
#define MICROPY_HW_UART3_RTS (pin_B14)
#define MICROPY_HW_UART3_CTS (pin_B13)
Thanx for the answer. Based on the above requisites, do you think that the following pin configuration is a viable choice:
CASE 1
1x UART: Y9, Y10 (+ flow control Y6, Y7)
6x digital input: Y8, X9, X10, Y1, Y2, Y3
CASE 2
1x ADC : X1
3x digital input: Y8, X9, X10
1x DAC: X6
3x digital output: Y1, Y2, Y3
[quote=dhylands post_id=24513 time=1515602861 user_id=81]
The RTS/CTS pins aren't shown there, but from the board definition file:[code]#define MICROPY_HW_UART2_RTS (pin_A1)
[/code]
[/quote]
CASE 1
CASE 2
1x ADC : X1
1x DAC: X6
[/code]
[/quote]
Pins for hardware flow control are in the docs. I have successfully used this feature via the pyb library.
Hello Peter,
thanx for the answer. Can you give me an opinion related to the pin configuration in the above post (CASE 1 and CASE 2) ?
pythoncoder wrote: ↑Thu Jan 11, 2018 5:44 amPins for hardware flow control are in the docs. I have successfully used this feature via the pyb library.
Both look fine to me. All pins on the long sides of the Pyboard can be used for GPIO if they aren't being employed for their specialist purposes. The drawing lists limitations on the pins on the short side of the board but you aren't using those.
So, for example, would it be possible to use X1 X2 for UART, X3 as GPIO, X4 as GPIO, X5 as DAC , X6 as GPIO and X7 as ADC ? (to know if I can mix pins used for their special function and used as GPIOs even when they are placed in different columns in the drawing)
pythoncoder wrote: ↑Thu Jan 11, 2018 10:01 amBoth look fine to me. All pins on the long sides of the Pyboard can be used for GPIO if they aren't being employed for their specialist purposes. The drawing lists limitations on the pins on the short side of the board but you aren't using those.
Yes. Each pin can individually be specified as GPIO if you aren't using any of that pin's specialised functions.
