UART IRQ/Callbacks and Class Example
Posted: Mon Feb 19, 2018 1:58 pm
by donikuy
I have managed to send and receive data via UART on the pyboard, but have been unable to do that using interrupts. Please see code below. Documentation indicates that irq is available:
>>> import pyb
>>> from pyb import UART
>>> uart1 = UART(1,baudrate=9600)
>>> uart1.irq(UART.RX_ANY,priority=1,handler=print('Uart callback!'),wake=machE)
AttributeError: 'UART' object has no attribute 'irq'
How can this be fixed? Is there amother way or any example of how I can use irq/callbacks to detect uart incoming messages?
Ideally I would like to create a UART class that performs this functionality.
Thank you.
Re: UART IRQ/Callbacks and Class Example
Posted: Tue Feb 20, 2018 6:07 am
donikuy wrote: ↑Mon Feb 19, 2018 1:58 pm
...Documentation indicates that irq is available...
I don't know where you found that.
The official docs have no reference to this as far as I can see.
There are various ways to use the UART. You can poll
any() to see if data is available. If you don't mind methods which block until data is received you can use the character or line reading methods. The most elegant way is to use
uasyncio: UARTS are stream devices and can be run as asynchronous tasks. The following code fragment performs concurrent I/O on a single UART and can be tested with a loopback between pins X1 and X2:
import uasyncio as asyncio
uart = UART(4, 9600)
async def sender():
swriter = asyncio.StreamWriter(uart, {})
await swriter.awrite('Hello uart\n')
await asyncio.sleep(2)
async def receiver():
sreader = asyncio.StreamReader(uart)
res = await sreader.readline()
print('Recieved', res)
loop.create_task(sender())
loop.create_task(receiver())
loop.run_forever()
The point here is that you can have other tasks running concurrently while the
receiver task pauses pending input.
Posted: Tue Feb 20, 2018 4:05 pm
by donikuy
Thank you for your help.
I think i will need to add the uasyncio module to my python project and load, build the project using cmake and then load it onto the pybv1.1.
At the moment I am having trouble with my cmake. Would you be able to send me the new dfu file the includes the uasyncio module please?
Posted: Tue Feb 20, 2018 4:47 pm
I suggest you look at the tutorial in
here which describes the installation of
uasyncio. There is no need for a special build - you can simply copy files across.
Posted: Wed Feb 21, 2018 1:13 pm
by donikuy
Thank you. I have copied the files over and i am now trying to run this script:
async def bar():
count = 0
count += 1
print(count)
await asyncio.sleep(1) # Pause 1s
loop.create_task(bar()) # Schedule ASAP
loop.run_forever()
I get the below error:
AttributeError: 'utimeq' object has no attribute 'peektime'
Would you be able to tell me what the problem is?
Posted: Thu Feb 22, 2018 8:51 am
I think you have an out of date firmware version. Please upgrade.
Posted: Wed Jan 10, 2024 9:36 pm
by Alexel
pythoncoder wrote: ↑Tue Feb 20, 2018 6:07 am
async def sender():
loop.run_forever()
for some reason this code is not working for me. nothing happens.
esp32 s2, v1.22.1
