When developing new micro python how do you debug it.
When a program crashes how do you find the line number and exception code?
How do i find out the line number of a bug
Re: How do i find out the line number of a bug
There is no debugger.
If the program crashes (as in segfaults) then you remove code until it doesn't crash anymore, then add code one by one. And report a bug on github.com/micropython because it's not supposed to crash.
If the program terminates because of an unhandled exception, that gets printed e.g. on the command line including stack trace with files and line numbers.
I'm getting nothing just a pyboard with no led on or flashing. Nothing is being passed back up the usb or at least linux handles it without printing the text in a terminal.
No experience with pyboard, did you look in the 'pyboard is dead' and other threads on the forum for hints?
@rhubarbdog It would help if you could explain exactly what you are doing. You mention Linux: what program are you using to connect to the Pyboard and how are you invoking it? Are you seeing a REPL prompt? If so, does a one-line program work?
If you're not getting a REPL prompt have you checked your USB cable?
>>> print('Hello')
Hello
Doing some further searching accross the internet. I've found the following putting your main loop into a function called 'main' put you program into a file called 'something.py' (never main.py or boot.py).
From a repl prompt type the following [/code]import something
something.main() [/code]
That's correct. Once your program is debugged, if you want it to run automatically at power up, you make main.py read:
To go back to debugging the program you can simply replace main.py with a version with those lines deleted or commented out.
import my_module
my_module.main()
