This seems to be a nearly identical clone: http://www.icstation.com/stm32f4-microp ... 11882.html
Does anyone spot a difference?
Thomas
PS: I wouldn't recommend buying that board. Micropython is also funded by selling the original boards and buying cheap clones will hurt the development of Micropython!
Clone from the original PyBoard
Re: Clone from the original PyBoard
I found the first change. Seems that they cut the cost on the voltage regulator. My pyboard uses 5 Microamps in pyb.standby() - the chinese Board uses 50 Microamps.
There are others too, even one which copies the board one by one (same formfactor, same connectors, same board labelling), just worse manufacturing = not worth the savings.
