I want to use REPL while using uasyncio
Meekdai
Post by Meekdai » Wed Jun 06, 2018 5:03 am
When using uasyncio, the program is looping and cannot use REPL.Is there a way to achieve both at the same time?
Here is my code:
import uasyncio as asyncio
async def blink1():
    bled=LED(4)
        bled.toggle()
        await asyncio.sleep_ms(1000)
async def blink2():
    gled = LED(2)
        gled.toggle()
        await asyncio.sleep_ms(2000)
loop.create_task(blink1())
loop.create_task(blink2())
loop.run_forever()
I try to use REPL while using _thread, It is working. But this article says “Threads Are Bad”. what should I do?
Re: I want to use REPL while using uasyncio
Post by pythoncoder » Wed Jun 06, 2018 7:35 am
When a Python program is running the REPL is unavailable. This is normal behaviour for Python and is independent of MicroPython, uasyncio or anything else. The REPL is there to launch programs and to examine their behaviour after they stop (intentionally or owing to an error) or are interrupted.
The purpose of uasyncio is to enable individual program tasks to run with an illusion of concurrency; it doesn't provide a means of running the REPL concurrently with a program.
As to whether what you want is achievable with _thread the short answer is that I don't know.
Meekdai
Post by Meekdai » Wed Jun 06, 2018 7:48 am
Thanks , I use _thread to solve my problem.
I found that when using _thread , REPL work well.
import _thread
def blink( threadName, delay):
    gled = LED(2)
        gled.toggle()
        time.sleep_ms(delay)
Tblink=_thread.start_new_thread( blink, ("Thread-1", 500, ) )
FraggaMuffin
Post by FraggaMuffin » Mon May 29, 2023 4:46 am
