Maximum number of PWM or how to get more
I need 24 PWM channels, I can see that I can easily get 20 but is there any way to break out more? or some kind of trick I can use?
I do know I can get SPI controlled PWM controllers but I need to be able to choose the PWM frequency.
Does anyone have any ideas?
Re: Maximum number of PWM or how to get more
It really depends on the PWM frequencies and duty cycles that you need.
Well it doesn't need to be accurate frequency just somewhere in the audio range and 8 bit 0-255 is fine.dhylands wrote:It really depends on the PWM frequencies and duty cycles that you need.
It a peculiar application, it involves being able to hear the pwm that is used to control 8 RGB LED's without multiplexing and the pyboard only other task would to be read a text file and send the values to the LED's.
I guess I could use something like this? http://www.adafruit.com/datasheets/tlc59711.pdf and change the frequency through EXT_CLK?
But it would be great if you know if I can somehow break out 4 pins?
To do hardware PWM (using a timer), you need the pin to have a timer capability / alternate function.
As you saw, there are 20 X/Y pins that can do this.
Extra IO pins that have a timer on them are:
So you only need 1 more... the options are PC8, PC9, PA8 (sd card) and PA9, PA10 (usb):
- PB4 = LED_BLUE has TIM3_CH1
- PA15 = LED_YELLOW has TIM2_CH1
- PB3 = X17 = SW has TIM2_CH2
- PC8, PC9 have TIM3_CH3, TIM3_CH4 and TIM8_CH3, TIM8_CH4. They are the D0 and D1 data pins of the sd card. You would need to de-solder the SD card to get at them.
- PA8 has TIM1_CH1 and is the SD card switch. You might be able to get at this with a fine wire connected to the switch bit of the sd card holder, on the top left next to pin Y3. Plug in an SD card to see the 2 pieces of metal come together.
- PA9 is USB VBUS. If you're not using USB then this would be the easiest to get to, since it's broken out on the bottom of the board, on 1 of the the OTG pads. If you are using USB, you can still use this if you desolder R10.
- PA10 is USB ID which is also not needed if you don't use OTG (which isn't supported in software yet...). You'd need to desolder R16.
Thanks so much for your reply! that might work, I did try to use the blue led one but am I right in assuming it is not supported in the pyb.timer library? https://micropython.org/doc/module/pyb/Timer
how would I go about assigning and controlling these timers in micropython, do I have to use a bit of C?
I did experiment in REPL with this, but I cant get it to work.
I would like to keep the USB functionality and the SD card for data but could I get away with stealing the switch from the SD card whilst it still works?
I guess PA10 is an option.
but even so how would I go about re-assigning them, is it quite low level?
thanks for your help!
>>> timer = pyb.Timer(3, freq=1000)
ValueError: Timer 3 is for internal use only
Actually, you can use the DAC on X5 to make a repeating square wave of any frequency, thus synthesising a PWM (using an analog output!). Or you could use the analog output directly to fade the LED (but that's harder than using PWM to do it due to nature of how LEDs work).
So you don't need to salvage one from the SD card or USB.
To use the TIM3_CH1 PWM of LED_BLUE you can just call pyb.LED(4).intensity(value) and that will set the PWM for you. If you end up needing low-level access then you can use the stm module (no need for any C code!).
Also, since X17 and LED_YELLOW need TIM2, you can't use TIM2_CH1 for X6. Instead you would use the DAC on X6.
All in all I think it's *just* possible to get 24 PWMs. And you can do it all in Python without modifying the hardware!
Here is what you'll need to use to get 24 PWM:
X1 TIM5 CH1
X2 TIM5 CH2
X3 TIM5 CH3 (or TIM9 CH1)
X4 TIM5 CH4 (or TIM9 CH2)
X5 DAC(1)
X6 DAC(2)
X7 TIM13 CH1
X8 TIM14 CH1
X9 TIM4 CH1
X10 TIM4 CH2
Y1 TIM8 CH1
Y2 TIM8 CH2
Y3 TIM4 CH3 (or TIM10 CH1)
Y4 TIM4 CH4 (or TIM11 CH1)
Y6 TIM1 CH1 negated
Y7 TIM12 CH1
Y8 TIM12 CH2
Y9 TIM2 CH3
Y10 TIM2 CH4
Y11 TIM1 CH2 negated
Y12 TIM1 CH3 negated (or TIM8 CH3 negated)
X17 TIM2 CH2
LED_BLUE TIM3 CH1
LED_YELLOW TIM2 CH1
Timer(3) is used only by LED_BLUE, and so you can use pyb.LED(4).intensity(value) to set that one (and it's already configured).
X5/X6 on the DACs can be configured using a custom square wave.
The rest you can use normal PWM settings. Note that for the negated channels the PWM duty cycle is inverted.
X1 TIM5 CH1
X2 TIM5 CH2
X5 DAC(1)
X6 DAC(2)
X7 TIM13 CH1
X8 TIM14 CH1
X9 TIM4 CH1
X10 TIM4 CH2
Y1 TIM8 CH1
Y2 TIM8 CH2
Y6 TIM1 CH1 negated
Y7 TIM12 CH1
Y8 TIM12 CH2
Y9 TIM2 CH3
Y10 TIM2 CH4
X17 TIM2 CH2
LED_BLUE TIM3 CH1
LED_YELLOW TIM2 CH1
For the negated channels, you can also use PWM_INVERTED instead of PWM and then the duty cycle remains the same.Damien wrote:Here is what you'll need to use to get 24 PWM:
Thanks for your help, will try and work out the code and perhaps report back here when I get stuck!
How would I go about setting a square wave in the DAC? what would make the pulse width change?
There is an example of sending a sine wave here: http://docs.micropython.org/en/latest/l ... ml#pyb-dacclack wrote:Thanks for your help, will try and work out the code and perhaps report back here when I get stuck!
A square wave would only use 2 values: 255 and 0
The pulse width would be determined by the number of 255's in a row you have.
