Hi everyone
I just received my MicroPy board and when i plugged it in (Win10) I received two comm ports in my device manager but no drive to access.
I can access REPL through terminal
Device Manager
Python Board USB COM Port 5
Python Board USB COM Port 6
Thanks again!
No USB HardDrive With The four main files. Help
Re: No USB HardDrive With The four main files. Help
Update.
I am doing as much research as i can on this, but i did a
import os
os.listdir('/flash")
in REPL and the 4 files are there. But they are still not showing up on COM 5 as a drive on windows 10.
I tried to manually install the Driver pybcdc.inf on Com 5. that did not change anything.
Let me know MicroPython board maker guys.
import os
What brand of board is it? Is it a genuine pybV1.1 from Damien or something else? It sounds like something with a dual USB to serial chip or debugger like ST-LINK. Genuine Pyboard won't generate 2 serial ports. Anything with a USB to serial chip won't create a USB dusk drive on the host.
Post a photo, web link or the part numbers of the main chips to help diagnose it.
!#*SOLVED*#!
Thank You chrismas9 For responding.
It is a Genuine PyBoard1.1 that i bought from Sparkfun.
I SOLVED the Problem. When I plugged the Board In i would get two com ports Com 5 And Com6 .
I disabled Both com ports.
uninstalled both device drivers.
unplugged the PyBoard And plugged it Back in and Voila,
The appropriate drivers assigned themselves and the magiC drive appeared.
Peace Everyone.
Peace Everyone.
