Timer callback function
thejoker
Post by thejoker » Thu Aug 30, 2018 7:01 pm
Dear reader,
I am trying to make sense of the micropython timer.callback() function, but I can't say I understand it very well.
My idea was to use the following code to call a function every 1 second:
def tick():
    print(time.ticks_ms())
# Create timer which calls the function 'tick' every second
tim = pyb.Timer(1, freq=1)
tim.callback(tick)
However, I get the following error:
>>> uncaught exception in Timer(1) interrupt handler
TypeError:
Does anyone know why this happens and what a possible solution is?
Many thanks in advance!
thejoker
Re: Timer callback function
Post by thejoker » Thu Aug 30, 2018 7:21 pm
I found the problem:
Note: Memory can’t be allocated during a callback (an interrupt) and so exceptions raised within a callback don’t give much information
Online
Post by dhylands » Thu Aug 30, 2018 8:09 pm
This page has quite a bit of information about writing interrupt handlers in MicroPython. In particular, to get more detailed information about exceptions, you should allocate an emergency exception buffer:
http://docs.micropython.org/en/latest/p ... ion-buffer
Post by pythoncoder » Fri Aug 31, 2018 6:06 am
There is a bug in the code. If you read the timer docs you will find that the callback takes one argument, the timer object. The following works:
def tick(_):  # Accept and discard the arg
tim.callback(tick)
