RTC refuses to set
rhubarbdog
RTC refuses to set
Post by rhubarbdog » Fri Sep 07, 2018 11:15 am
hi
I've been playing with the real time clock RTC.
i had this working earlier now setting the RTC with `pyb.RTC().datetime((a-tuple))` just hangs for a few seconds and fails to reset the clock.
This is my program
clock = pyb.RTC()
print("Enter date as revesed tuple (Y,M,D,0,H,M,S,0)")
get_date=input("Enter the 0's and ()'s :")
clock.datetime(eval(get_date))
    pyb.delay(1000)
    print(clock.datetime(), end="   \r")
i believe from experimentation the date is entered as a tuple Year, Month, Day, <don't know>, Hours, Minutes, Seconds, <milliseconds??>
I currently enter
(2018,9,7,0,12,13,0,0)
it hangs for a second or two and prints
(2000, 1, 1, 1, 0, 0, 0, 0)
shaoziyang
Re: RTC refuses to set
Post by shaoziyang » Fri Sep 07, 2018 12:29 pm
Sometimes RTC may not initial correctly after power on, then RTC not running. You may try clock.init() to re-initial RTC.
Post by pythoncoder » Sat Sep 08, 2018 5:31 pm
The tuple looks good - it's documented here.
I have seen exactly that symptom and agree with @shaoziyang that it usually implies that the RTC crystal oscillator is stopped. This can occur for various reasons: the circuitry around the 32KHz crystal is quite sensitive and handling the board while powered up (or with the RTC running off a backup cell) can stop it. Check for anything untoward electrically.
