heap_lock heap_unlock not working
New account, so no code tags, sorry
When I run this code I get a MemmoryError: memory allocation failed, heap is locked
import micropython
micropython.heap_lock()
micropython.heap_unlock()
Running this also locks the heap:
import micropython
My setup is: MicroPython v1.9.4 on 2018-05-11; PYBv1.1 with STM32F405RG
Is this a bug or am doing something wrong?
Thanks for any help
import micropython
import micropython
Thanks for any help
Which line causes the error?
What are you trying to do?
Re: heap_lock heap_unlock not working
Reproducible on Windows builds, doesn't seem right indeed (so either it's a bug or it is not supposed to be used that way, didn't check the docs).
and
>>> import micropython
MemoryError: memory allocation failed, heap is locked
>>> (press Ctrl-D here)
FATAL: uncaught NLR 0F702020
>>> import micropython
>>> (press Ctrl-D here)
FATAL: uncaught NLR 0F282020
I can replicate this with firmware built today. This is evidently a bug. I'll raise an issue.
[EDIT]
Now done issue 4205.
[EDIT]
The responses on the issue explain the behavior.
You can't use the console with the heap locked, and heap_unlock without a previous lock "fails".
Thanks everyone!
Thanks everyone!
@Polo Your observation of a crash after two calls to heap_unlock did show up a bug. A PR with a fix has now been submitted.
What about if you call lock 65536 times?pythoncoder wrote:@Polo Your observation of a crash after two calls to heap_unlock did show up a bug. A PR with a fix has now been submitted.
You're doing an infinite recursion and are about to crash the stack
I doubt this is remotely likely in a real application. Handling it properly (rather than just increasing the size of the counter) would be nontrivial. But if you feel inclined to submit a PR, I'll study it with relish
Since we're handling underflow, we should definitely handle the overflow case.pythoncoder wrote: ↑Thu Oct 04, 2018 4:32 amYou're doing an infinite recursion and are about to crash the stack
There should be an exception if you have a lock-depth of more than 65535.
See discussion here issue 4205.
