heap_lock heap_unlock not working
Posted: Tue Oct 02, 2018 1:23 pm
by Polo
New account, so no code tags, sorry
When I run this code I get a MemmoryError: memory allocation failed, heap is locked
import micropython
micropython.heap_lock()
micropython.heap_unlock()
Running this also locks the heap:
import micropython
My setup is: MicroPython v1.9.4 on 2018-05-11; PYBv1.1 with STM32F405RG
Is this a bug or am doing something wrong?
Thanks for any help
Posted: Wed Oct 03, 2018 2:36 am
by jickster
Which line causes the error?
What are you trying to do?
Re: heap_lock heap_unlock not working
Posted: Wed Oct 03, 2018 8:29 am
by stijn
Reproducible on Windows builds, doesn't seem right indeed (so either it's a bug or it is not supposed to be used that way, didn't check the docs).
>>> import micropython
MemoryError: memory allocation failed, heap is locked
>>> (press Ctrl-D here)
FATAL: uncaught NLR 0F702020
and
>>> import micropython
>>> (press Ctrl-D here)
FATAL: uncaught NLR 0F282020
Posted: Wed Oct 03, 2018 8:38 am
I can replicate this with firmware built today. This is evidently a bug. I'll raise an issue.
[EDIT]
Now done
issue 4205.
Posted: Wed Oct 03, 2018 8:05 pm
by Polo
The responses on the issue explain the behavior.
You can't use the console with the heap locked, and heap_unlock without a previous lock "fails".
Thanks everyone!
Posted: Thu Oct 04, 2018 4:19 am
@Polo Your observation of a crash after two calls to heap_unlock did show up a bug. A PR with a fix has now been submitted.
Posted: Thu Oct 04, 2018 4:24 am
by jickster
pythoncoder wrote:@Polo Your observation of a crash after two calls to heap_unlock did show up a bug. A PR with a fix has now been submitted.
What about if you call lock 65536 times?
Posted: Thu Oct 04, 2018 4:32 am
jickster wrote: ↑Thu Oct 04, 2018 4:24 am
What about if you call lock 65536 times?...
You're doing an infinite recursion and are about to crash the stack
I doubt this is remotely likely in a real application. Handling it properly (rather than just increasing the size of the counter) would be nontrivial. But if you feel inclined to submit a PR, I'll study it with relish
Posted: Thu Oct 04, 2018 9:47 pm
by jickster
pythoncoder wrote: ↑Thu Oct 04, 2018 4:32 am
Since we're handling underflow, we should definitely handle the overflow case.
There should be an exception if you have a lock-depth of more than 65535.
Posted: Fri Oct 05, 2018 9:16 am
See discussion here
issue 4205.
