CC3000 wifi not coming up after cycling EN low/high
mischko
Post by mischko » Wed Feb 11, 2015 11:35 pm
I pull EN low after doing my network connection and send.
I'm doing this to reduce power consumption of the CC3000.
When I pull it high again, I can't get the CC3000 working again.
If I do not pull EN low, this works great but draws around 130mA.
Code:
print ("Setting up SPI and PINS")
SPI = pyb.SPI(2)
CS = pyb.Pin.board.Y5
EN = pyb.Pin.board.Y4
IRQ = pyb.Pin.board.Y3
print ("Initializing NIC")
nic = network.CC3K(SPI, CS, EN, IRQ)
print (nic.ifconfig())
print ("Connecting to WIFI")
nic.connect(WIFISSID, WIFIPWD)
while not nic.isconnected():
pyb.delay(50) #milliseconds
s = socket.socket()
print ("Connecting to Web server")
s.connect((SERVERADDR, SERVERPORT))
print ("Sending GET")
s.send('GET /temp?rm=mbr&t=%s&b=90 HTTP/1.0\r\n\r\n' % int(gettemp()))
print ("closing up for a while")
s.close()
print ("NIC disconnecting from WIFI")
nic.disconnect()
print ("Setting EN low")
EN.low()
print ("delaying")
pyb.delay(60000) # 60 seconds.
print ("Setting EN high")
EN.high()
pyb.delay(100) #milliseconds
Here are the run results:
Initializing NIC
('0.0.0.0', '0.0.0.0', '0.0.0.0', '0.0.0.0', '0.0.0.0', '00:00:00:00:00:00', '\\')
Connecting to WIFI
('192.168.0.12', '255.255.255.0', '192.168.0.1', '68.105.28.11', '192.168.0.1', '08:00:28:58:dd:2a', 'B4843F')
Sending GET
Setting EN low
delaying
Setting EN high
Initializing NIC
File "tempclient.py", line 18, in <module>
OSError: failed to init CC3000 module
Can someone please explain the proper sequence of events to get the CC3000 back to a usable state after the delay?
Frida
Re: CC3000 wifi not coming up after cycling EN low/high
Post by Frida » Mon Feb 22, 2016 9:52 am
I have a strippet down example.
Notice I have put in:
a=[('0.0.0.0')]
b=tuple(a)
EN.low()
pyb.udelay(250)
while (b == nic.ifconfig()[0:1]):
	print('...waiting...')
	pyb.delay(200)
At last you only need to set EN.low() at the end, because nic = network.CC3K(SPI, CS, EN, IRQ) will set it high.
import socket
a=[('0.0.0.0')]
b=tuple(a)
SPI = pyb.SPI(2)
while (True):
	EN.low()
	pyb.udelay(250)
		pyb.delay(200)
	print(nic.ifconfig())
	s = socket.socket()
	s.close()
	nic.disconnect()
	EN.low()
	pyb.LED(4).on()
	print ("delaying")
	pyb.delay(10000)
	pyb.LED(4).off()
	print('')
Yes Frida is my watchdog!
