LCD, AMP, Bluetooth, and Battery
pythoncontroller
Post by pythoncontroller » Mon Feb 16, 2015 10:17 pm
Hello all,
Is it possible to use the LCD skin, the AMP skin, the Bluetooth module, and a battery to power the board and modules simultaneously? If it is possible, how would it be connected?
Thank you in advance for any help!
Re: LCD, AMP, Bluetooth, and Battery
Post by dhylands » Tue Feb 17, 2015 6:06 am
You should be able to.
The AMP skin would be mounted in X position and the LCD skin would be mounted in the Y position.
This photo shows the LCD screen mounted in the Y position: https://www.dropbox.com/s/5jjoodfarmb46 ... 8.jpg?dl=0
Looking at the schematic for the AMP board: http://micropython.org/resources/AMPv10-schematics.pdf the X1-X4 pins are not used and there is a UART on X1/X2 and X3/X4, so you should be able to connect the bluetooth that.
You can power the pyboard using VIN. I think that the buetooth module nees 5v, so you'll need a voltage regulator for that.
pythoncontroller
Post by pythoncontroller » Mon Feb 23, 2015 9:59 pm
Thank you for the quick response! I will try connecting them all soon.
