How to fast read and write data to file?
skylin008
Post by skylin008 » Thu Nov 15, 2018 9:59 am
Hello everyone. I had a pyboard with stm32f405 chip. I want to read data from SPI port and write to flash with file. I found it every slowly as below code.How to solve with it ? Thanks !
from pyb import Timer
from pyb import Pin
from time import sleep_us
from time import sleep_ms
from machine import SPI
import uio
# spi pin
spi_ss   = 'Y5'
spi_sck  = 'Y6'
spi_mosi = 'Y8'
spi_miso = 'Y7'
# switch pin define
switch = pyb.Switch()
# led pin define
red_led    = pyb.LED(1)
green_led  = pyb.LED(2)
orange_led = pyb.LED(3)
blue_led   = pyb.LED(4)
all_leds = (red_led, green_led, orange_led, blue_led)
pcm_sync = Pin('X1', Pin.OUT_PP)
pcm_sync.low()
sleep_ms(10)
def sync_out(timer):
	pcm_sync.high()
	sleep_us(10)
	pcm_sync.low()
sample_amount = 2048
class SpiControl:
	def __init__(self):
		self.spi = SPI(2, baudrate = 2048000, firstbit = SPI.MSB, polarity = 0, phase = 0)
		self.ss = Pin(spi_ss, Pin.OUT_PP)
		self.dummybuf = bytearray(1)
		for i in range(1):
			self.dummybuf = 0xff
	def read(self):
		response = bytearray(1)
		self.ss.low()
		self.spi.read(1)
		self.ss.high()
		return bytes(response)
spic = SpiControl()
data_buffer = [[] for i in range(sample_amount)]
start_flag = 0
	print("Programme Start!")
	sleep (1)
	if switch.value():
		print("Key Pressed!\r\n")
		tim = Timer(2, freq = 8000)
		tim.callback(sync_out)
		start_flag =1
	if (start_flag):
		print("START2!\r\n")
		if (spic.read())!= 0xff:
			for loop_value in range(sample_amount):
				data = spic.read()
				data_buffer[loop_value] = '{},'.format(data)
		with open('pcm.dat', 'wb') as pcm:
			for each_data_value in data_buffer:
				pcm.write(each_data_value)
Re: How to fast read and write data to file?
Post by OutoftheBOTS_ » Thu Nov 15, 2018 10:33 am
You are doing it in a very slow way.
You are just reading 1 byte at a time then your also writing 1 byte at a time. It takes much longer to start up the read or start up the write then to do the reading or writing.
You should be able to do it all in 1 hit something like this
buff = bytearray(sample_amount)
spi.read(buff)
	pcm.write(buff)
skylin008
Post by skylin008 » Fri Nov 16, 2018 1:51 am
@OutoftheBOTS_ Thanks ,I will be try.
