from pyb import Timer
from pyb import Pin
from time import sleep_us
from time import sleep_ms
from machine import SPI
import uio
# spi pin
spi_ss = 'Y5'
spi_sck = 'Y6'
spi_mosi = 'Y8'
spi_miso = 'Y7'
# switch pin define
switch = pyb.Switch()
# led pin define
red_led = pyb.LED(1)
green_led = pyb.LED(2)
orange_led = pyb.LED(3)
blue_led = pyb.LED(4)
all_leds = (red_led, green_led, orange_led, blue_led)
pcm_sync = Pin('X1', Pin.OUT_PP)
pcm_sync.low()
sleep_ms(10)
def sync_out(timer):
pcm_sync.high()
sleep_us(10)
pcm_sync.low()
sample_amount = 2048
class SpiControl:
def __init__(self):
self.spi = SPI(2, baudrate = 2048000, firstbit = SPI.MSB, polarity = 0, phase = 0)
self.ss = Pin(spi_ss, Pin.OUT_PP)
self.dummybuf = bytearray(1)
for i in range(1):
self.dummybuf = 0xff
def read(self):
response = bytearray(1)
self.ss.low()
self.spi.read(1)
self.ss.high()
return bytes(response)
spic = SpiControl()
data_buffer = [[] for i in range(sample_amount)]
start_flag = 0
print("Programme Start!")
sleep (1)
if switch.value():
print("Key Pressed!\r\n")
tim = Timer(2, freq = 8000)
tim.callback(sync_out)
start_flag =1
if (start_flag):
print("START2!\r\n")
if (spic.read())!= 0xff:
for loop_value in range(sample_amount):
data = spic.read()
data_buffer[loop_value] = '{},'.format(data)
with open('pcm.dat', 'wb') as pcm:
for each_data_value in data_buffer:
pcm.write(each_data_value)
